Curious, IMO a quench/squish design piston is the best way to go for a marine app that's constantly under load and on the edge of detonation....a flat top or full dish will work, but if I were rebuilding a marine engine, I'd quench it.....my two cents.32pacemaker wrote:.....best used with flat top pistons.....
5.7L GM Vortec Advantage?
Re: i have done many vortec installs
- Struts and Rudders
MarinePower
Try Marinepowerusa.com
I bought two 6.0 with transmissions and saved a ton.
They even did custom white paint for me.
SRD
F36
SRD
F36
Re: MarinePower
6.0's let us know your burn rate, heard they could be gas hogs in 36' plus boats.Struts and Rudders wrote:Try Marinepowerusa.com
SRD
F36
that's nice..mitch wrote:Did I say Vortec, go to bed
SRD
F36
I have heard the same. I understand that the mapping and control systems have been re calibrated for the base power plant and consumption has been reduced...but I am sure it is still not gonna be pretty at WOT.
I worked very closely with Cameron Gilly at MarinePowerusa.com and they intend to map my engines to the application.
You must also know that we intend to use the boat as a coastal cruiser and will most often be at a very slow cruise or maybe better described fast idle. I put the 6.0 in for the HP if we need it and re-sale.
SRD
1980 F36
SRD
F36
SRD
1980 F36
rooferdave
SRD
F36
SRD
1980 F36
I have a 6.0 vortex in one of my trucks, the fuel burn in my truck is obscene! 128 liters gets me just over 400 kms which is 32 liters per hundred kms or 42 dollars for 100 kms....translated to english its 42 dollars per 60 miles! I cringe at what that would be in a boat...
When I did my rebuild last year I looked at a lot of options. checked on all the long block remans....for me on the west coast i was concerned about buying anything from the east coast...sure they all have a warranties but you have to haul the boat, pull the motor and send it back...I decided to have a local reputable marina do the rebuild and own the warranty.....cost more but for me the piece of mind was worth the extra cost..........my 2 cents......John
1998 Kawasaki ZXi 1100
32pacemaker wrote:vortec big advantages are in the heads with high flow ports and fast burn combustion chambers. you can use the vortec heads on an old block best used with flat top pistons and ends up at about 9.4:1 compression make sure you use an external bypass for the coolant because the older heads use a hole drilled in the head for coolant bypass. limit your ign timing to 28 degrees max, and use a rail style rocker arm stock or better yet a roller tip from comp cams
This is why this site is so great. The wealth of knowledge from its members.
MY CURENT FLEET
2003 KEY WEST 2020 WA
1978 ASHCRAFT 14' SKIFF
