1974 F-25 Salt Water Progress
jefflaw35
Post by jefflaw35 »
Library-
Painting- http://www.yachtpaintforum.com/brightsi ... ic496.html
rudder fab- http://www.lightthenightboatlights.com/
LED Lighting- http://www.superbrightleds.com/cgi-bin/ ... _prods.htm
http://www.lumiteclighting.com/
neon lighting- http://www.marinemachining.com/
paints- http://www.pettitpaint.com/catalog_brow ... ictNbr=262
http://www.propspeedusa.com/
engine rotation- http://www.marineengine.com/boat-forum/ ... marine-318
cooling systems- http://www.boatpartsinfo.com/2010/05/ma ... xchangers/
Wiring- http://shop.genuinedealz.com/
http://www.marinco.com/productline/adhe ... eat-shrink
http://www.marinco.com/productline/wire-cable
http://www.marinco.com/page/wire-tech-data
Trojan engine specs- http://boatspecs.iboats.com/Trojan_Yachts/bp/20br1516
wiring- http://bluesea.com/category/81/21/productline/126
gauges- http://www.vdo.com/generator/www/com/en ... ts_en.html
good prices- http://www.boatersland.com/search.php?m ... rch&page=1
Velvet drive- http://rnr-marine.com/TROJAN/Borg-Warne ... _Specs.pdf
http://rnr-marine.com/TROJAN/Borg-Warne ... atings.pdf
http://rnr-marine.com/TROJAN/Borg-Warne ... Manual.pdf
http://www.marineryachts.com/borg_manual.pdf
stuffing boxes- http://www.shaftseal.com/en/categories/300000001
window removal- http://www.trojanboatsforum.net/wforum/viewt ... ght=window
gas cap and gaskets- http://www.perko.com/catalog/category/f ... oduct/350/
stuffing box- http://www.pbase.com/mainecruising/stuffing_box
remodeling- http://www.themarineconnection.net/
Veeneer sales- http://woodworker.com/fullpres.asp?PART ... RGEVIEW=ON
exhaust- http://bpi.ebasicpower.com/c/ALL5A/Fibe ... t+Fittings
http://www.defender.com/
http://greatlakesskipper.com/
toilet system- http://www.boatus.com/boattech/casey/in ... g-head.asp
batt charger- http://www.xantrex.com/power-products/b ... e-2-2.aspx
water scematics- http://www.marineengine.com/boat-forum/ ... -schematic
http://www.pertronix.com/catalogs/ignit ... xignition-
318 water flow diagrams- http://www.trojanboatsforum.net/wforum/viewtopic.php?t=6508
Todds Marine- https://www.toddusa.com/products.aspx?id=64
oil changing kits- http://www.westmarine.com/webapp/wcs/st ... sNum=50402
http://www.westmarine.com/webapp/wcs/st ... BH3RaDyTcY
VHF antenna settings- https://dl.dropbox.com/u/10877359/vhf.pdf
http://www.boat-project.com/tutorials/vhfant.htm
carbs for 318's- http://www.edelbrock.com/automotive_new ... rine.shtml
jefflaw35
Post by jefflaw35 »
I was thinking so Tman, not sure how well its going to work tho after it piles up with pictures and etc.. guess well see. Im sure we will be stealing alot of ideas from each other, Deff gonna take alot longer than I expected. but its fun.
jefflaw35
Post by jefflaw35 »
Finally a good day to pull the hard top.
I really wish someone would have found a better way with the hardtop wiring instead of butchering the head and hiding it with a window curtain.
Don't know why they didn't run the wiring through the aft post instead!?
jefflaw35
Post by jefflaw35 »
Im looking into that right now, just found myself in the funnest wire chase of my life. Half of this boat is wired with speaker wires for power reason lol. This is a mess and sidetracking me. Fun tho
Torcan
Post by Torcan »
All I can say jeff to you is don't get discouraged. Take it one step at a time.
Because it looks like your attacking everything at once, and you could become overwhelmed.
http://www.cbyc.ca/
Nancy
Post by Nancy »
jefflaw35 wrote:This Ftard is my PO hero. 8 power wires ran with speaker wire and the temp sending unit gauge dead ends in the cabin about 12 feet from the motor. Ummmmmm...
You crack me up! I'm pretty sure there won't be one square inch of this boat you don't know. And you certainly won't have any surprises!
Torcan
Post by Torcan »
jefflaw35 wrote:dunno nancy, I found a funny looking tool under the motor when i dropped my wire cutters, nothing suprises me LOL, looks like a wrench but has points on it, ok hard to say but it has metal nipples on it like it unlockes something, im sure i will find out what , lol
post up a pic of it, I am sure you will get a quick response
http://www.cbyc.ca/
Sounds like the tool used to remove the flange that secures the disc to a grinder.
jefflaw35
Post by jefflaw35 »
Torcan wrote:All I can say jeff to you is don't get discouraged. Take it one step at a time.
i know buddy and thanks for your help, i am trying to do to much at once. the warm/cold weather isnt helping. im just bouncing all around, but i am documenting with my ipad so i can jump back and forth. its going good so far, technology is a good thing
maybe the deck plate tool for the fuel and water tanks
here one type
http://www.ebay.com/itm/VALMAR-STAINLES ... ar&vxp=mtr
jefflaw35
Post by jefflaw35 »
sorry guys ill try again tomorro. its look just like a flat 1 inch wrench and has to nipples for locking on it. i dropped it under the engine, cant reach it, in the cold and dark. its just something i found on the boat, no big deal really.
Good guess Paul, could be. :idea:
jefflaw35
Post by jefflaw35 »
glad i got few good friends like you here Nancy LOL life is fun!! keep it moving
jefflaw35
Post by jefflaw35 »
any how!! this PO wasnt to bright
back to factory i think.qat least wha i add is looking better
