Got the new motor yesterday
It looks good, not sure how much you can go by looks tho!
The boat is getting there the bottom paint gets soda blasted Weds. I still cant find anyone to crane the old engine out for me but I have time.
a bunch of new pics on the blog, take a look!
trojanmanXS
yep looking empty there. Ive just doen the same to mine now tell me how was it cleanign that "ick" of the hull inside? I was able to get it all off my hull here. only thing that cut through all that cr*p was this product called purple power found it at lowes I tried 4-5 different degreasers/cleaners ect but this stuff worked great . keep up the good work
Do you know anybody with a skid steer or a tractor backhoe? I built a quick-tack cherry picker for my 863 bobcat & works great for pulling boat motors. Just gotta watch the load rating on the machine & how far out front you're picking. Mine will get tipsy with big block 454s, I just add a few more suit case weights to the rear of the skidder & pick away. It does get tricky if the boat is on stands, but with a good operator there's nothing to it. Just throwing that option out there?
If you have Cat shop around give them a call? They will sent out there boom truck also, but hold on to your shorts when you get the bill.
Twin 318 powered 1976 F28 "Think BIG IIi"
Larry- I used TKO Orange, $85 a gallon made 5 gallons and soaked it for 48 hours - used a pressure washer - came out nice but I should have covered head liner!
Capt. I got a crane guy $400.00!!
I am trying to disconnect shaft from transmission but the nuts are frozen. My nuts fell off trying to get them free!
I can't disconnect trans from engine while it's in the belly of the beast so out they both shall come!
mr elevman
the rebuilt is in the garage, the old one is on the boat but completely free and ready to get lifted out. I am going to leave the trans attached and have that pulled as well. Probably the first week in October. I'm going to build the new one and fire it up in the garage before I attempt to re-install. I am not going to re-install until March.
