Detroit Diesel 671TI Rebuild
Jerry
Post by Jerry »
Putting the rings on.
Sliding the piston assy into a new sleeve.
Assemblys all boxed up ready to go down to the boat. The boxes worked great to keep the rod stable while in transport.
Jerry
Post by Jerry »
A look into the piston to see how the rod bolts to the slipper bearing and pin.
Here is the tool that we used to remove and install the new sleeves.
For those of you that are thinking that looks like a bearing hub, you are correct.
John from the machine shop machined the edge of it so it was a perfect fit sitting on a sleeve without being able to move. It really worked out well.
Rod bolt condoms on rod bolts to protect the bearing journel from nicks while installing.
Tool on sleeve to push it home.
Jerry
Post by Jerry »
A shot through the air box at the new assemblies.
Isn't that a beautiful site!
All sleeves in and everything bolted up.
I had to order a few gaskets and o-rings so not much more we could actually do at the time so we went back to Daves shop and returned to prepping parts.
We did a lot of blasting, priming and painting.
Here is Dave in action at his shops paint booth.
The next step is to put the oil pump back on and then the oil pan. After that I will clean the living ship out of the bilge and lower the enging back down onto it's mounts. That will be a glorious day.
rossjo
Post by rossjo »
Yes sir - that will be a glorious day. Always a pleasure to see a job done right.
Looking good . Did you check the sleeve height ?
Jerry
Post by Jerry »
prowlersfish wrote:Looking good . Did you check the sleeve height ?
You bet. We ended up with them all being the same.... right inbetween the min and max spec. I was pleased with that result.
Audrey II
Post by Audrey II »
well did you fire them up yet? You left us hanging. I hope it all turns out great for you.
1996 Trojan 440
We all really appreciate the effort in sharing the rebuild with us.
Jerry
Post by Jerry »
We still are not done and it is very slow going for me as I have to go in for back sugery. That is going to screw up this summer for me for sure. As of now it looks like I am having it done at the end of June.
But, for an update, the oil pump is back on, the oil pan with the new pad heaters is installed. the bilge was cleaned and the engine now sits where it originally was. It was nice to see it lowered into place.
The tranny was bolted back up and the shaft has also been reattached.
We have to leave the frame work in for now as I am still waiting on the head to be finished. We will use the two chain falls to lower it back into place as there are a lot of little sealing rings that need to be in place at that time.
The oil cooler has been installed, the puke cans, a block heater (as long as the blower was off I installed a block heater also just in case I ever need it. I will keep it there and just not plug the pig tail in at this time) Some oil lines that supply the oil cooler( so much for the clean bilge as one of the rubber gloves ripped that we had over the hose ends and oil spilled all over the freshly cleaned bilge floor), the drive hub for the blower, and the last thing to go back on was the blower itself.
Sorry that it has been so long since an update but I was feeling very poorly for a while with the drugs that they had me taking and at this time of year we are really busy at work. Not to mention I am three guys short so it has been a bit rough lately.
I will get some new pics up soon.
Thanks to everyone for keeping their interest.
Jerry
Post by Jerry »
Here is the oil pump bolted back up and the gear lash checked.
Oil pan with gasket on all set to go back in place
Pan back on
Jerry
Post by Jerry »
Blower drive gear and hub being prepped to reinstall
It goes in the top left hole here
Engine being lowered
Sitting on the front mounts
Jerry
Post by Jerry »
Transmission being aligned. That ended up being a bit tricky.
Tranny back on, rear mounts back bolted on to stringers and the shaft being reattached
And there it sits!
Jerry
Post by Jerry »
I hope everyone noticed the clean bilge in that last pic.
Unfotunately it did not stay that way for very long.
Jerry
Post by Jerry »
I can't sit any longer as I have to get up and move around.
I will finish getting caught up after a little break.
Jerry
Post by Jerry »
Air box covers going back on
Port side air box covers, one puke tank and a couple of oil lines
One more oil line
Other puke tank all set to go
