Fuel Tank Removal
Yeap got to watch the poly tanks., a few boat makers went to them and it didn't work out so well. Think on it poo hoses and tanks have to be changed out due to smell. And the last thing I would want is gas and fumes in my boat. Imo
Paul,
can you smell diesel through the poly tanks? I have been considering poly tanks when I repower, however, if you can smell diesel through them, then no thanks.
I kind of thought they would be good because they're translucent, so I could see the fuel level, they wont corrode and they should be quiet.
Your experience would be appreciated
I don't know on the diesel part. The EPA is now setting specs on small Polly tanks , the tanks now have to be thicker or made differently to allow less fumes to escape. Not sure if any changes will happen on larger tanks . From what I have seen poly tanks do ok for awhile then after a few years you get some smell . they say its safe but to me smell = fumes
no thanks
no thanks
juswinginit
mickeydd
justwinginit.......... Dont mind me asking what are you doing or replacing your old tanks with?
I'm up in the air now on what type of material to replace mine with. Doing the job in 3 weeks time...... have to order something soon though. I thought I seen the ice melting the other day...have to un-cover the "ole" girl............lol
Mickey
Mickey
juswinginit
