Stainless Steel Manifolds????
foofer b
It is time to change my manifolds and risers. An aquaintence mentioned using stainless steel manifolds and risers . Said you could then go 8 or 9 years between changes. Anyone heard of this? Are they a lot more expensive. I found EBasicpower.com for regular manifolds. He mentioned Imco or Stainless marine.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
heard they last longer, but also heard they can be leakers due the to metals heating and cooling differently, Iput the Merc ceramic coated on to seasons ago and I'm happy with them.
- vabeach1234
What engine do you have?
Is your engine fresh water cooled or raw water?
I have a Chrysler 318 and have the exhaust manifolds part of the closed cooling system. The transmission and v-drive are raw water cooled though. The raw water dumps out of the elbows which are about $100 a piece. My elbows are due to be replaced but seeing how the manifolds are freshwater cooled, they should last a lot longer.
It may be cheaper to get a freshwater cooling kit if you don't already have one than to get stainless mainfolds. I don't think they make stainless exhausts for the Chrysler 318.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
Hampton, VA
The exhaust isn't fresh water cooled. The the block and manifolds are cooled by ethyl glycol in a closed loop, just like a car engine. The raw water that cools the glycol in a heat exchanger is then dumped into the risers and exits through the exhaust.
1980 Trojan Hardtop Express
Salvaged former Aux CG Patrol Boat
wowzer52 wrote:I've never heard of fresh water cooled exhaust since the water that cools them goes right out the exhaust pipe.
Coolant ( fresh water ) runs Thu the manifold a long with the engine salt or raw water goes Thu the riser . the use the same manifolds and risers but use a a gasket ( or plate) with no coolant holes in it between the manifold and riser .
If you where to buy a fresh water system for your engine a half system would be engine only and a full system would be engine and manifold cooling. a lager heat exchanger is used on the full system.
If you whole engine is Raw water cooled I wouldn't waste the money on any S/S sense sooner or later the heated salt water will EAT your block, I'd just keep using stock ones and carry on until good'ole mother nature gets you..
These guys seem like they know what they are doing, plus will help you with advice of how to plumb for closed or raw water cooling.
prices are pretty low too
httphttp://www.mooreperformance.info/Mercru ... ifold.html
I'd stay cast iron, aluminum, steel and salt don't mix well and then there's the over and under torque of the aluminum and block . Both heat at different rates I think it would or could be a P.I.T.A in the long run .imo
