Any of you fellow F30 owners know if there is a hatch on the cabin floor which would allow me access to the hull, my cabin floor has carpeting. I have to fix a through hull fixture that used to be a depth sensor. Previous owner plugged the hole with a dowel then a thin fiberglass layer, I don't trust it, I think it would be best to repair it with another through hull fitting, seeing as I need a depth sensor anyway as the boat doesn't have one.
Next, I purchased a trailer that needs to be modified to a bunk model, The rear bunks will be easy enough to add as the frame width matches the width of my boats chines, I'm thinking all I need for the forward supports are a couple keel rollers. I'm just wondering if a couple is enough or if I need more. This is NOT a highway trailer, just a wintering trailer as I don't want to be married to a marina and their sling and cradle method.
A couple questions about my newly aquired F30
Miss piGGy
Landlocked! Yes, but that won't deter me from trying to find my way out to sea.
Miss piGGy
Well that is good news, I had visions of having to r&r the interior to fix the hole. Thanks guys, I don't like the green carpet that is in there anyways, I'd like to change to a wood floor in the cabin, this may be the time to do it. What kinda flooring do you all have in your cabin?
i was going to go with hard maple flooring that i took out of an old farm house. i even have the boards all stripped,sanded and ready to go in but i scrapped the idea and went with carpet. i was worried about it coming loose with all the flexing and jarring.
~john wayne~
~john wayne~
