Rudder Stuffing Boxes
Molly Too
Post by Molly Too »
I need to either adjust or repack my F32 rudder stuffing boxes. It looks like I need to hang upside down in the lazerette hatch and sill work with a mirror. Anyone out ther have any suggestions or experience with this?
Mel Spruill
Molly Too
'87 F32
On mine there easy to get to from the rear hatch ,but the 32 maybe diffrent
rossjo
Post by rossjo »
I sit down between them and reach everything pretty well. Not a lot of room to work, but I can get them loose with some effort..
Is that diagram SPECIFIC to our brand or general?
Mine do leak and I got a set of plastic bearings some years ago from John Leed at Marine Tech, however I have put off that job.
Doesn't look like too much fun and to be honest, it seems a bit daunting, especially regarding frozen parts and saltwater.
Does anyone know if the Internationals are the same as the F series?
I believe thats a generic diagram . On my F36 the rudder arm is on top .
rossjo
Post by rossjo »
Thats the F32 rudder.
Paul - when you say your F36's "rudder arm is on top", what do you mean?
"when you say your F36's "rudder arm is on top", what do you mean? "
I mean that the rudder arm is on top
The rudder (tiller ) arm is above the coller and bearing nerar there top of the rudder shaft
rossjo
Post by rossjo »
I checked mine yesterday, and my tiller arm is also at the top.
So, apparently, this picture is NOT representative of the F32 or F36 rudder setup. It must be a generic drawing, but it is very similar on the lower mounting, etc.
wowzer52
Post by wowzer52 »
My arms also are on top. I tighten my rudder packing about once a year to stop it from weeping and soon I will be raplacing them but they are easy to get to like rossjo said.
1975 F-32 "SIMPLY BLESSED"
rbcool
Post by rbcool »
No joke here........ In the rare instances I can't get to them I give a local 10 yr old $20 to wiggle down there and do it while I'm up top giving instruction. Just a thought.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
rossjo
Post by rossjo »
Turns out this "MOTOR YAHCT RUDDER - PORT" is from PAGE 6 of the "FAMILIARIZATION - POWER TRANSMISSION SYSTEMS" of my 1976 Trojan Owner's Manual.
It may not represent wha's in our boats, but it is what in the Trojan manual.
rossjo wrote: Image
