Caterpiller 3208
Tuck
Caterpiller 3208
Question: Is the Caterpillar 3208 a good, reliable marine engine? Also, are 2200 hours something to worry about, or is this within "okay" range for this engine?[/img]
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
Danny Bailey
what Danny said.
what Danny said.
cats
are you considering thses cats for your F32?
I believe that the engine is to tall to fit into the engine compartment of the F32 and the stringers may not support the wieght and torque without substantial added support
HP to wieght ratio not very good
is the engine already marinized? if not, could be cost prohibitive to convert
2200 hours for a cat diesel, just barely broken in if they were maintained
Good engine . below 375 hp great engine . at 375hp can last a good while in not ran real hard and taken care of . at 425 hp the same goes only more so. if its below 375 hp 2000 hours is nothing ( if taken care of )
As far as being big and heavy for power Rating I don't fully agree compared to a yanmar Yes , compared to a Detroit No.
No that boat looks pretty bad , but its the only one I could find with the Cat listed . I saw real nice one a year or 2 back . Trojan did put the cummins 504 in the F36 I belive it was aprox the same size . I am not sure what if any diesels where offered in the F32 .
Danny Bailey
As with most everything else about a boat, engine selection is a set of compromises:
weight vs horsepower
cost vs durability
horsepower vs fuel use
size vs engine room space available
operating envelope vs performance desired
Without adequate consideration and analysis you most likely will end up with a boat you don't like
cost vs durability
