bottom painting
farfrompuken
bottom painting
Post by farfrompuken »
OK gentlemen, what do you guys paint and don't you guys paint? props, shafts rudders,trimtabs, strainers, all ,some and/or which ones?
'72 F-31 Express Flybridge JUST US TWO
Twin 270 Crusaders
16' Glassmaster Center Console
hangout:ZACKS BAY Long Island ,New York
http://s390.photobucket.com/albums/oo350/farfrompuken/
George and Joanne Holzmacher
Rodman
Post by Rodman »
do you think if I use low vol sand blasting on the bottom it will hurt it? I want too repaint mine as well.
Trojan
9rock
Post by 9rock »
Rodman wrote:do you think if I use low vol sand blasting on the bottom it will hurt it? I want too repaint mine as well.
I posted twice
9
9rock
Post by 9rock »
I would start with a 3000-4000 psi pressure washer with a 0 degree oscillating tip first , , if more cut is needed u can get a attachment for sand or even better glass beads, always do a small test spot first, light scratching is OK in fact it helps tooth the barrier coat but chipping is bad
It worked well on my boat with a soft ablative . but my friends boat had a hard paint and it did not do as good, he ended up sanding it down with DA sander with 60 grit barrier coat and 2 coats of paint,
9
Rodman
Post by Rodman »
9
Thanks for the info.
Trojan
9rock
Re: bottom painting
Post by 9rock »
farfrompuken wrote:OK gentlemen, what do you guys paint and don't you guys paint? props, shafts rudders,trimtabs, strainers, all ,some and/or which ones?
I paint all except zincs and transducers
9
choice of paint equally important.
Match the paint to the water and consider if the boat comes out of the water.
I paint the bottom with ablative and use propspeed on the props, shafts and rudders . if I did not use prop speed I would paint the running gear .
foofer b
Post by foofer b »
prowlerfish, what is propspeed?
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
MTP
Post by MTP »
TIKI III
1985 F32
270 Crusaders
Wet and happy
Jersdevil
Post by Jersdevil »
We use soft ablative paint on the bottom and Future acrylic wax on the props and shafts. Tried it last year after an old timer told us about it seemed to work pretty good. Also put Cayenne pepper in the bottom paint.
Hank Newman
"Winsome" 1979 - F30 Clean Machine
First Sergeant, U.S. Army Retired
Co-Owner Don Snyder
turtlem1969
Post by turtlem1969 »
if you use a sand blaster to blast the bottom, use baking powder on it, it will take the bottom paint off and leave the gel coat looking like it was sanded with 80 grit.
BJ
1972 F25HT "Billy Bob"
1974 36' Tri-Cabin
Tuck
Post by Tuck »
Whatever you do...make certain you get the type you can apply while the boat is still in the water. 8)
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
wowzer52
Post by wowzer52 »
:lol: :lol: :lol:
1975 F-32 "SIMPLY BLESSED"
Danny Bailey
Post by Danny Bailey »
I used to paint all the underwater running gear until I discovered Lowes tarps. Propspeed looks impressive by the claims, but man it looks like a pain to install, and costs as much as my spring haul-out.
