fridge help.....
Paul - SW Ontario
Post by Paul - SW Ontario »
turtlem1969 wrote:paul, theres no insulation on the back side of the fridge, or any where on the boat. I think I have got it figured out though, I took the door off the fridge and its still about an inch to wide, it looks like I can take the door frame off the cabin and gain about 2 inches, gonna try that tomorrow.
All good....sounds like that will work.
Nice & easy with the teak... :wink:
Damn near like gold!
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
turtlem1969
Post by turtlem1969 »
i hear ya there, if i mess up the teak, I got a ton of brazilian mahogany I can replace it with, but thats a lot of work to replace it all, so hopefully i wont mess it up.
larglo
Post by larglo »
Come to think of it, after I took off the fridge door, I did have to take the door frame off to have enought room to remove the fridge from the cabin! I'm real sorry I forgot about that. :oops:
Larry
Larry - 1980 F25 HT
"Lady G"
Mt. Juliet, TN
turtlem1969
larglo, its all good, we all suffer from sometimers from time to time. :lol:
Jp860
Re: fridge help.....
Post by Jp860 »
turtlem1969 wrote:I have a 25 trojan ht, the fridge in it has gone bad, I have unhooked all the wires and the 115 plug, removed it from its resting place, went to take it out the door, and guess what????? it wont fit thru the door, any tips or suggestions, short of removing the rear cabin wall.
Use a sawzall onit
Jp860
Post by Jp860 »
Use a sawzall on the fridge cut it right in half
Peter
Post by Peter »
don't screw up the trim, screw up the fridge [sawzul]....I hope you are sensing a theme here
turtlem1969
so is that a saws all thru the fridge or around the top of the cabin? :?
turtlem1969
Thanks all for the input. old fridge cut in half and removed, new fridge installed and no trim got messed up, just have to add some trim around the new fridge to make it look like it belongs there.
Jersdevil
Post by Jersdevil »
SAWZ-ALL the Duct Tape of power tools. :lol:
Hank Newman
"Winsome" 1979 - F30 Clean Machine
First Sergeant, U.S. Army Retired
Co-Owner Don Snyder
mr elevman
Post by mr elevman »
if the sawzall dosent work get in toutch with rodman he may have a few extra flairs around with as many times hes changed props
Bad ,very Bad idea
Peter
Post by Peter »
funny though. :lol:
plasma arc :shock:
FriZer
Post by FriZer »
Just like what many people said. Try to taking out the fridge door. I know and I believe that it is the best solution for your problem. I once experienced and tried and it works properly.
