tech specs
mr elevman
tech specs
Post by mr elevman »
does anyone have a shop manual for a 318 im looking for torq and sequence for heads and intake manifold
Rodman
Re: tech specs
Post by Rodman »
mr elevman wrote:does anyone have a shop manual for a 318 im looking for torq and sequence for heads and intake manifold
SMALL CHRYSLER273, 318, 340, 360 A Engine
Fastener Type Torque Spec
Main cap bolts 85 ft.-lbs.
Connecting rod bolts (plain) 45 ft.-lbs.
Cylinder head bolts, 273-318 85 ft.-lbs.*
Cylinder head bolts, 340-360 95 ft.-lbs.*
Rocker shaft bracket bolts 17 ft.-lbs.
Intake manifold bolts 35 ft.-lbs.
Oil pump cover bolt 95 in.-lbs.
Oil pump attaching bolt 35 ft.-lbs.
Oil pan bolts 15 ft.-lbs.
Cam locking bolt 35 ft.-lbs.
Cam thrust plate bolts 210 in.-lbs.
Harmonic damper bolt 135 ft.-lbs.
Flywheel/flexplate bolts 55 ft.-lbs.
Flywheel housing to engine block bolts 50 ft.-lbs.
Flexplate to torque converter bolts 270 in.-lbs.
Clutch housing bolts 30 ft.-lbs.
Front cover bolts 30 ft.-lbs.
Water pump bolts 30 ft.-lbs.
Trojan
mr elevman
thanks would you allso have the tighting sequence of the head bolts and intake manafold
Here's the torque sequence for the 318 (5.2) intake manifold on the right, from a later model. It'll be the same.
And here is the torque sequence for the cylinder head. (the V-6 is shown also, pay no attention to it...it has two less bolts)
mr elevman
thank you hum any idea what ill be doing. i picked up a 240 hp 318 std rot fwc moter, that looked like hell but fired rite up. comp cheak was good on all clys. oil was good needs manafolds and risers outside of moter took a salt water bath 500$ so befor i put it in to replace my bad port moter im braking it down and replacing all the gaskits oil pump timing chain and gears main seals head gaskits ect but first its getting soda blasted on sunday morning then torn down. yea for me
Rodman
Post by Rodman »
mr elevman wrote:thank you hum any idea what ill be doing. i picked up a 240 hp 318 std rot fwc moter, that looked like hell but fired rite up. comp cheak was good on all clys. oil was good needs manafolds and risers outside of moter took a salt water bath 500$ so befor i put it in to replace my bad port moter im braking it down and replacing all the gaskits oil pump timing chain and gears main seals head gaskits ect but first its getting soda blasted on sunday morning then torn down. yea for me
Can I such jest you buy all new head bolts. I rebuilt a Isuzu NPR couple years back when I was torquing the head, one broke on me. Lucky it broke above the block. So I had to remove the head buy new head gasket and replace all the bolts.
Trojan
No need to replace the bolts on that engine ( the 318), just inspect them. On some engines you need to replace the bolts as they are not reusable, this is not one of those
