f28 packing
f28 packing
Some one please help me i have a 1978 f28 with twin 318's with v drives and would like to know can i change the packing on the shaft with the boat in the water and if so what is involved? thanks in advance Keith
I have seen it done where the nut was removed and slid up the shaft which allowed water to flow in freely into the boat until a rag could be tucked into the shaft log around the shaft. The rag slowed the flow to a light trickle while the packing was replaced in the nut. The rag was then removed and the nut put back into place quickly. The bilge pump had the boat dry again within a few minutes.
Although this method works, I personally prefer to haul the boat out to replace a packing. This allows you the oportunity to inspect the shaft where the seal rides.
One more thing that you might consider, if you plan on keeping the boat for a while, is a mechanical shaft seal. I installed a LasDrop shaft seal in mine in 2000 and have had a dry bilge (except when I wash it) ever since with no maintenance. They are a little pricey though so if you plan on selling the boat in a few years, you're probably better off to replace the packing.
Will be testing this version of almost dry packing this year...
http://www.e-marine-inc.com/products/gf ... ml#measure
Rodman
That`s what I bought and put in mine.ready123 wrote:Will be testing this version of almost dry packing this year...
Trojan
Good stuff holds up well .
I do mine in the water , I don't see why one would unbolt the shaft .
If you have never done it in the water don't panic when the water flows in
If you think about it the clearance between shaft and box is not that large, also it is not that far under water so small head of water, it does not gush in as you seem to think it would...... no need for a fire pump.
