sliding glass door f-36
vandukw
Post by vandukw »
my sliding door to salon does not want to slide, I think it has lost a wheel or it has a flat spot on one....How do you get the door out to check or replace slider wheels? I cant push it up high enough to get it off track and out? anyone had this prob.???
Buckknekkid
Post by Buckknekkid »
use a bottle jack to lift the center of the flybridge Should clear by a quarter of an inch. the rollers are steel and not generally available.
F36 ~
SHES SOLDDDDDD
I think Bob sells the wheel kits here ( http://www.trojanboats.net )
Safari
Post by Safari »
Underneath the slider is a molded aluminum piece that has 4 screws holding it in. When you remove the screws, pull the piece towards you - The door will come off with the piece (might need 2 people for this one). When its off, pull the long aluminum bracket off to expose wheels. Get the right wheels!
mintregila
Post by mintregila »
Check in Home Depot. You will pay $60 for a set from Bob and $12 there.
Mark I.
