f-32 weight
f-32 weight
buying a trailer for future boat anyone know the weight of a f-32 thanks mike
F-27 EXPRESS
Problem is not weight 12,000 lbs dry... problem is beam of 13 feet and bridge height (14' 6" to 15' on a trailer)... also requires wide load permits to move it on public roads.
Basically you will need a lowboy hydraulic trailer.... mucho $$ for a good one.
What exactly are your plans for moving it? If not frequent and high quantity you are better off paying for a hauler with trailer to move it.
NOTE: you cannot store it on that kind of trailer as they do not support it in the correct points for long term storage.
Now building a cradle for storage might be worth doing.....
Says clearance on cradle of 11' 6".... that must be with bridge removed!
Not as minor as you might think... The bridge surround is easy but the console within the bridge is actually higher than the surround once wind deflector and railing are removed.chauzer wrote:approx weight must be dry weight. flybridges are easy to take off
A large number of wires to be disconnected from the bridge console as well as disconnecting the shifter cables from the shifter before it can be removed. The hydraulic steering likely has quick disconnects.
It is certainly not a complex job but it is very time consuming and something that would become a real pain if done twice a year IMO. Why I initially suggested using a lowboy trailer which generally allows one to move an F32 with only rails and deflector removed.... that has been my experience anyway. (14' 6" max height on trailer)
The OP has yet to explain why he needs to own a trailer for an F32.... I'm interested in hearing how it is intended to be used. It is entirely possible that he was thinking an F32 is only 5 ft longer than a F27 so it can also be trailerable.....
Not to cloud the issue- I've been told that the 12k weight figure commonly provided is for the base boat only (options not included) ... may not even include the flybridge. There was also some suggestion that early boats may have been laid-up heavy in the early stages of glass construction.
I've not had mine on certified scales but both the hauler and the lift operater estimated my F-32 at around 16K. Food for thought.
needless to say most of us dont have the truck to pull a f32 let6 alone make it stop on a down hill
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
16,000 isn't bad if you got good trailer brakes. i have pulled 22,000 with a 2500hd. granted it was a goose neck but it pulls just fine. the cool thing with boats is when you have them put on the trailer you can balance the boat to load or unload tounge weight.
~john wayne~
~john wayne~
