Crusair Question...Air AND Heat?
Tuck
okay, stoooopid question i know (at least i know when i'm going to ask something stupid...usually), but maybe someone can tell me so it won't drive me nuts until i get to the boat tonight...
i have the original cruiseair unit on a 77 f 32. the control has 3 knobs: start/on (run), fan, and one (bottom one) that says warmer and cooler.
my question is this: is this a reverse cycle heating unit as well? is that answerable without crawling down in there and getting a number off the unit?
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
If it is from the 70's I would expect it to be air conditioning only (cooling)....
are you planning a move North to need heating??
Tuck
smartass!S.A.M. wrote:Not to be a smarta$$, what happens when you turn it to heat?
actually, i don't know. i hadn't thought about it until today after reading another post about a free control unit. made me think about what i have. so far, i've only run the air. i've been using the singer heater on the few nights it's been needed.
i'll be up to the boat in about 2 hours. i'll fire it up and see.
Terran
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
I have both A/C and Heat on one unit and just a/c on the other the controls look the same . turn it to warm and see if the compser turns on and run it for about 10 minites to see if you get heat . the coolder the water the less heat you will get . when the water gets to 40 deg. it will be useless
- aaronbocknek
our 1972 f-36 tri cabin had the reverse cycle unit using the same 3 controls. cruisair did not use any other type for a very long time. also, they began making reverse cycle marine units starting in the mid to late 1960's. just remember, it is a 'heat pump' of sort, so the cooler the water, the less it will heat up. if you turn the temp knob to 'warmer' and after a while it does not feel like warm air is circulating in the cabin, chances are, it is just the basic 'cool only' unit.
aaron in baltimore
aaron in baltimore
If you can pull a serial number off the unit cruisair can tell you if it is reverse cycle. Or you can look for the reversing valve usually located near the compressor. It is the only electric valve on the refrigerant lines. These reversing valves are notorious for sticking, especially if not exercised. So if you turn your control "warmer" but get no heat, it may be the fault of the reversing valve.
Brett
Brett
You have a reverse cycle air / heat system. My 1979 F32 has the same setup. I have used the heat setting but only rarely - on heat the unit tends to trip the breaker from time to time. I use a small ceramic heater as I find it quiter and it delivers more consistent heat. I usually only use the reverse heat when the ceramic guy needs a boost.
I believe I have a copy of the manual at home - or might be able to find the pdf on the web again - if you need it. Think mine is a 16,000 BTU Crusair. I think it is one of the 'Stow Away' units here : http://www.tritex.com.sg/products/manuf ... m#stowaway
