winterizing- water pump question
Boaterguy
Post by Boaterguy »
Do you pull the impeller out of your water pump for the winter?
It seems that I have heard somewhere that this is a necessary step.
Any thoughts?
1975 F25
318 RH
Sea La Vie
I do so the curved blades won't set.... others at my marina don't. I have not heard any conclusive evidence that what I do is an advantage but since I loosen all the belts too it is not too much extra work.
Main advantage is that at the start of every season I can visually see their condition.....
Ready123 has some good points .I know some folks that do remove them and I would think it would help add life to them One other thing you can do is bump the engine over once in a while ( that is good for the enigine) But you will not be able to see the impler condtion.
On the other hand If you pulling the impler anyway why not replace it they are cheap.
If you do remove it and reinstall it . make sure it goes back in in the same way ,if you don't you will twist the blade the other way and shorten the life quikly
prowlersfish wrote:On the other hand If you pulling the impler anyway why not replace it they are cheap.
Up here with our 1/2 yr season, two seasons use is not too much of a stretch.
true . we have a sail boater that pulls it every year and gets 5-6 years out of them it takes him hours to do it if I would spend hours doing it I would just replace it every few years and not pull it . I sure you don't spend hours doing it ( I hope its easier)
think about it 4 hours labor a year to save 25 bucks LOL but thats a sail boater for you :lol:
Boaterguy
Post by Boaterguy »
Once again, thanks for the great info.
I will pull it apart and take a look at the impeller.
At this point I am still getting to know the boat, and this will be a good way to practice replacing the impeller. If it looks like it is still in good condition I will reinstall- if not I will order 2 new ones (one back up) and replace in the spring.
thanks
1975 F25
318 RH
Sea La Vie
aaronbocknek
Post by aaronbocknek »
i do what my dad did on our tri cabin for decades. i 'bump' the impellers twice a month for the engines and genset. besides, it gives me an excuse to tell phil 'i need to go to the boat to do some work'. by now he knows that 'an hour of boat time' is 4 hours of standard time. and with the marina 7 miles from the house, it's an easy excuse!
aaron in baltimore.
aaronbocknek@gmail.com
mtwolf
Post by mtwolf »
Aaron,
I don't pull mine although I do remove the belts every year to prevent the belts from taking a "set." I rebulit my pumps last year so I should be good for awhile.
John
F-31
MD
