F-32 Shower Drain...This makes the 3rd Question
Tuck
Post by Tuck »
Sorry, I knew there was something else I needed an answer to...
My shower drain is draining painfully slow. The pump is running, but the drain appears to be clogged (I assume the pump is okay). My question is this: What can I use to unclog these pipes, if that's indeed the problem? I've not used the normal methods, i.e. Liquid Plumber, etc, because I'm not sure if the pipes, which I assume are original, could handle it.
Advice, please.
Thanks again.
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
LSP
Post by LSP »
Have Glenda bring by one of her snakes....
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
Tuck
Post by Tuck »
LSP wrote:Have Glenda bring by one of her snakes....
lol
Ya know. I feel just about retarded. I dunno why I didn't think of a snake before making the post.
Guess that's what I get for trying to sneak a net-run while in the office.
Tks. A snake it shall be. Although, I don't think Glenda's has them. lol
Terran
Terran
(former 1977 F-32)
My f 36 has a screen between filter ( screen ) and the pump near the pump . you may want to check that .
JuiceClark
Post by JuiceClark »
prowlersfish wrote:My f 36 has a screen between filter ( screen ) and the pump near the pump . you may want to check that .
mine was draining slow once and I checked that little screen at the pump. It was packed full of sawdust from when I sanded the cabinet and <somebody's> nasty pubes. GROSS
Tuck
Post by Tuck »
tks for the replies. i didn't know this, and will check this afternoon when i get to the boat.
hope it's that simple.
Terran
Terran
(former 1977 F-32)
Tuck
Post by Tuck »
tks guys! once again, you guys come thru!
i found the pump, and sure enough, found a small filter in the line. took it out, and the screen inside was covered with gunk thicker than michael jackson's media coverage.
took it outside, took it apart, cleaned it, stuck it back in, and wala! drain works better than it has since i've had the boat.
now, on to the next issue i can hopefully tackle myself...the placement of the transducer.
tks again guys!
Terran
Terran
(former 1977 F-32)
jwrape
Post by jwrape »
For Future reference I have plunged mine before and loosened up the junk in it to get it flowing again.
But then again, my shower pump hasn't worked in a couple seasons. The Belge has been taking care of the job. I have a new pump but just haven't gotten around to replacing it yet.
79' Carver 28' Mariner
