counter rotating props
Barry Boyle
I have a 1978 f-26 ( i think ) It has two 4cyl GM engines volvo penta SX outdrives the props both rotate the same is there any advantage to changing them to counter rotation. I beleive according to the shop manual I can just change the shift cables. I have had some handling issues in the past nothing too serious I think I have them worked out
Re: counter rotating props
You would also have to change the prop to the opposite hand. Volvo stern drives can easily be reversed as you suggest.Barry Boyle wrote:I have a 1978 f-26 ( i think ) It has two 4cyl GM engines volvo penta SX outdrives the props both rotate the same is there any advantage to changing them to counter rotation. I beleive according to the shop manual I can just change the shift cables. I have had some handling issues in the past nothing too serious I think I have them worked out
The boat will run more efficiently, track true and be easier to handle at low speeds with contra rotating props.
Make sure you can get a counter rotation prop in the corect size double check with Volvo to make sure you can run it in the reverse direction . If it can be and you can get the prop go for it . I am surprised it was set up with the same rotation if it can be ran counter rotation .
