How to remove a F-28 dinette table
Ok heres another bonehead question. Is there a trick getting the table out of the brackets?? I've pulled and pulled. was on my back pushing up from underneath with my legs and this thing will not budge!!! I see no buttons or levers to push or pull!!! uugh!!
- robertBrown3232
Hold it up about 30 degrees and have someone else tap it up next to the hinge while pulling away from the hinge. It should pop out... then maybe all you need to do is clean the hinge parts and add a little zip lube for next time.gofish103 wrote:I've wiggled it, Ive jarred it, i've pushed and pulled!
the boats still dry, but we have a place at catawba moorings.
kevin babineau
OK... twist them using an oil filter chain wrench to loosen the seize.... then you should be able to pull them out.gofish103 wrote:mine isnt hinged. it is self standing, it has two posts that support the table. the posts are approximately 3 or 4" in diameter
It sounds like the table has never been removed. I removed the table and bases on my '76 F28 and love the added room. We use a small fold up table that we use inside and out. The only down side is that you lose the extra sleeping area if you remove it from the boat. But it sounds like it was never used as the double bed anyway.
- guglielmo6160
