Coolant Leak 671-t
kenryanrussell
Coolant Leak 671-t
Post by kenryanrussell »
Hello,
I have a coolant leak on the Detroits 671-t model. Can this be fixed with the vessel in the water, or does it need to be taken out of the water?
Re: Coolant Leak 671-t
You did not say what was leaking, but I can not think of any coolant leak that would require you to pull the boat out of the water. Can you give more details? And what boat?
Moderator
2026 Support
2026 Support
Post by Moderator »
More info?
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
