I'm looking for a source for the LM318-340 cast aluminum oil pan gasket. I really only need the 2 rubber strips at the ends as the side rail gaskets are the same as car & truck engines. Even if someone had old pieces that I could get measurements from would be very helpful.
Thanks much,
gsample
LM318-LMM340 cast aluminum Oil Pan Gasket?
Re: LM318-LMM340 cast aluminum Oil Pan Gasket?
I would give Beacon marine a call
Beacon Marine Supply © 2022
Forks Township, PA and Columbia, PA
bob at beaconmarinesupply dot com
609-713-4602
609-713-4602
