MCCK Generator nameplate location
Scott67
Post by Scott67 »
Good morning folks, I'm trying to locate a new/used drip pan for my generator for when I pull it out later this month. Looking all over the generator to no avail for a nameplate. Hoping you guys can shed some light on how else to determine the "spec" as there are three difference pans available depending on the spec number.
The hull number is: 340-8053, 1988 10m Intl. Mid-cabin
Thanks in advance for any assist.
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
Re: MCCK Generator nameplate location
Give Bob at beacon marine a call he knows the Onan very well
call Bob @ 609-713-4602.
Scott67
Post by Scott67 »
I called him just the other day regarding some electrical issues I was having. I feel like I'm being a pain, but I may do so because all my searches have turned up empty. They probably just don't make the pans for these oldies anymore.
"Speakeasy"
Model 340
1.5:1 Gearboxes
Jacksonville, FL
Bob may have one, or you could have one made.
If I recall, the spec plates were mounted on the flywheel and belt cover, this seems to be the first thing that goes missing and with it the info plate. I think the serial number is also stamped on the top of the block just behind the base of the lifting ring.
Scott67
Post by Scott67 »
Big D,
Thanks for that info. Yeah, the one on the flywheel cover (if there was one) is gone. The only plate on the cover is regarding oil recommendations for the MCCK Generators. I will look behind the lifting ring today for the numbers.
Thanks again!
Scott
"Speakeasy"
Model 340
1.5:1 Gearboxes
Jacksonville, FL
Scott67
Post by Scott67 »
No luck on the serial number research. Once I get the genny pulled next week and clean it up on the bench, perhaps I'll be able to locate something. I've decided to just make a pan for it....no luck anywhere for them.
"Speakeasy"
Model 340
1.5:1 Gearboxes
Jacksonville, FL
We have a drip pan
Always feel free to call
We are here to help
609 713 4602
