Is anyone familiar with this Crusader retrofit kit? https://www.marineengineparts.com/crusa ... l-line-kit
I purchased one from Beacon to replace a damaged flare fitting where the fuel line connects to the filter on the carb but the traditional fuel filters don’t fit in the new fitting (the blue part in the link above). The new fitting has a slightly smaller inner diameter, is tapered, and reduces the depth/length available for the filter.
Beacon is closed until the end of the month and no one else seems to know about this kit or what filter to use. Google is failing me. Any ideas? Thanks!
Crusader Retrofit Flex fuel line (pump to carb)
Joel
1984 F32 "Second Course"
Belle Maer Harbor, Harrison Township, MI
Re: Crusader Retrofit Flex fuel line (pump to carb)
Doh! Important details… 1984 Crusader 270 with a Rochester Quadrajet. I’ve used this filter in the past: https://marinepartssource.com/fuel-filt ... ra-18-7869
Joel
Send Bob a email
A very quick response from Bob:
“Crusader did not design the replacement hose to be used with the internal fuel filter.”
Thanks Bob. Thanks prowlersfish.
Joel
