Hydraulic fluid for the engine hatch on a 1994 Trojan 3700 Express
Mike
Post by Mike »
I recently purchased a 1994 Trojan 370 Express Cruiser and I'm having an issue with the hydraulic engine hatch. It will go up, but it does not appear to go up all the way. Might this be a hydraulic fluid issue, and if so, where is the pump and hydraulic fluid located?
Re: Hydraulic fluid for the engine hatch on a 1994 Trojan 3700 Express
No info on the Carver built boats . but but listen for the pump running to locate it or trace the hoses .
Mike
Post by Mike »
I did that, and again, the pump/switch appears to be behind the refrigerator in the cockpit, but no sign of where or how to check the hydraulic fluid. I was hoping someone might know. Thanks.
Mike
Post by Mike »
*370 Express
