No water flow to my starboard engine
Cjones43420
Post by Cjones43420 »
Hi all I’m not sure if I’m posting this I. The right location, but I’m not getting any water flow to my starboard engine and it’s running super hot. I’m not running it either at the moment
Re: No water flow to my starboard engine
Right location . First make sure thru-hull is open and clear , raw water pump belt is ok . Then check the impeller in the pump . . what boat and engines ?
Cjones43420
79 Trojan f28 Chrysler 318 engines
Have you done any work tp it to try and fix the issue ? Checked what I posted before ?
