77 F30 engine stall
Patriciamarie
77 F30 engine stall
Post by Patriciamarie »
I'm having trouble with the port engine, when hot the engine will shut down the closer you get base idle and occasionally pop through the intake under acceleration , I'm wondering about coil breaking down or timing advance issues, any ideas.
Steve
Re: 77 F30 engine stall
Stall is likly a carb issue maybe adjustment . Other issue could be carb but could be in the advance .
Patriciamarie
Adjusted timing with vac Guage to 20hg , readjusted carb . Problem solved. Thanks
