Stickey cables
AwayOnBusine$$
Stickey cables
Post by AwayOnBusine$$ »
Can anyone recall the article on freeing up sticky cables by forcing oil through with a compressor. On my list for this year.
F32 Fly 1975
gitchisum
Re: Stickey cables
Post by gitchisum »
I made the tools to do this with reinforced pvc tube, valve stem, hose clamps and marvel mystery oil per the post from the forum. I put in 15psi pressure and it took about 4 hours to get oil out the other end. Worked well! hope you have same outcome
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
AwayOnBusine$$
Re: Stickey cables
Thanks!
F32 Fly 1975
Re: Stickey cables
gitchisum wrote: Thu May 09, 2019 10:31 pm I made the tools to do this with reinforced pvc tube, valve stem, hose clamps and marvel mystery oil per the post from the forum. I put in 15psi pressure and it took about 4 hours to get oil out the other end. Worked well! hope you have same outcome
Works for sticky non-boat cables too. Hat tip to the OP of that idea!
Re: Stickey cables
AwayOnBusine$$
Re: Stickey cables
Thanks. Need to try this. Everything OK at lower helm. Much prefer to pilot from upper helm. Can get difficult to move port cable. Really causes problems when trying to back into a 14' space when you can't go from forward to reverse instantly in a cross wind.
F32 Fly 1975
