identity confusion
Re: identity confusion
I just tell marinas that it is a Trojan F-36 and let them decide. So far, I have never been charged for more than 36 feet, but have gotten comments that it is a bit bigger than expected.
Our boat tapes out at 39' 8" with bow pulpit and swim platform.
topseaturvy wrote: Sat Aug 18, 2018 3:55 pm That's really quite puzzling if that decal was added later. I mean what would be the intent? As you can make out if you look closely at the last two pictures. The windows are tinted very dark. Then there is a black band about 4 inches high which appears to be your typical adhesive vinyl. Then a space above that wide band about maybe 1/2" and then another strip above that which is about 1/4" wide also in black vinyl. These 2 vinyl bands go along the bottom of all the windows, lincluding the front ones as well. As I look close at the decal, I'm realizing that the grey shading is actually the only part that makes up the lettering and it's laid on top of the black.
Ok , Per Bob , and John Leeds ( A Trojan engineer ) A some research of my own they did not com on that boat or any Trojan built boat . They are likely a carver built Trojan decal that someone put on . Carver bought the name in 1992 . The numbers and photos all say you have a 11 meter sedan .
sounds like y'all solved the mystery
here's the proof:
https://www.boats.com/boats-for-sale/?m ... 00-express
topseaturvy wrote: Fri Aug 17, 2018 3:59 pm The numbers on that tag are 731-5017. After about 30 minutes of scratching my head trying to figure out how I would let you see a picture I took of that decal, I've given up. I don't think there are enough years left in my life to jump through all the hoops for that on here. Anywhere else on the internet it's such a simple process of clicking on that paper clip icon and in seconds the process is complete. The letter font style is a square black letter with rounded corners and the grey shading is to the right. All upper case letters and the J doesn't have a horizontal line across the top. Similar to the font style used here. It definitely looks like it was done at the factory.
Try posting photos now I think it will work better for you now
Sjunewick2
Post by Sjunewick2 »
Nice boat! I have an 11 meter Sedan also.
