Shower drain
Patriciamarie
Shower drain
Looking for schmatic of water system shower is very slow to drain the pump appears to draw slowly and very little water leaving the exterior port. Any ideas
Steve
Steve
Re: Shower drain
what model Trojan?
Patriciamarie
Re: Shower drain
Yes of course 77 F30
Re: Shower drain
on my '83 International Express the sump contains a small Rule 360 bilge pump with a float activated switch that simply pumps the water overboard.
This is also where the air conditioner condensate drains.
If yours is the same you might find hair or other debris in the bottom vanes of the pump that may impede its ability to move water.
Suggest you take a look at the underside of the pump.
Re: Shower drain
Also check the hoses for cracks. It could be draining into the keel.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
Re: Shower drain
I have f32. Where is the shower sump located? Under the shower pan?. Mine is not draining .
1974 f32 Sedan
Twin 233 Mercruisers
Re: Shower drain
It may not have one It may have a pump you turn on as needed . That's the way my F36 is .
- WayWeGo
Re: Shower drain
My 1975 F-36 also does not have a shower sump, so you have to run the pump the whole time you are using the shower. The A/C condensate drains into the bilge, which is not to my liking.
I have thought about adding a shower sump with a float switch and pump. If I do so, I will run the condensate drains to the sump as well. If I don't add a sump, I will be adding through hulls for the condensate drains to avoid the water going into the bilge.
Re: Shower drain
Fixed my shower drain today. It's a direct pump that comes right out. The hose was split..
1974 f32 Sedan
Re: Shower drain
Any way to quiet the pump it's kinda loud since it has to be on the whole time while showering.
1974 f32 Sedan
