HEI Distributors
zedtwentyate
HEI Distributors
Post by zedtwentyate »
I've seen a few posts about the HEI distributors from AAA Marine. Can anyone tell me any downside of using these? I am only hearing good things about HP add and economy...
Kegan
1986 Trojan F-27 (SOLD!!!)
Re: HEI Distributors
Are you talking about this style ?
https://aaamarine.com/chevpromarine-650 ... ser-owners
https://aaamarine.com/chevpromarinecomb ... -and-wires
IMO its a great design and if I had a weak moment and went back to gas :shock: , I would go that route .
zedtwentyate
prowlersfish wrote:Are you talking about this style ?
Yes. I just spoke to AAA today. Great guy there who sold me on them. I placed an order for two combo sets today. He said you have to run the plugs at .60 instead of .30 and it increases HP and efficiency.
Kegan
BobCT
Post by BobCT »
I'm interested in hearing the before/after comparison. I have the original distributors on mine with the Prestolite electronic modules. I replaced both and carry a spare. Dead reliable but could prob upgrade now.
zedtwentyate
BobCT wrote:I'm interested in hearing the before/after comparison. I have the original distributors on mine with the Prestolite electronic modules. I replaced both and carry a spare. Dead reliable but could prob upgrade now.
I have the same Prestolites now. The new ones should be here this week. Once we're put back together, I will let you know how they perform. I am a little nervous about moving away from "factory", but I have to believe the technology improvements make it ok to do.
Kegan
zedtwentyate
Anyone out there who has done this job...can you clarify what wires will be no longer connected to anything? I'm trying to wrap my head around this...
I know the HEI unit only needs tach and 12v...but there are at least three or four wires that will no longer have a home.
Kegan
Only 2 wires needed . The others can be removed or taped up
As Paul said, two wires only. You'll need the 12 volt ignition-on feed and the tach wire. Tape up and secure remaining wires.
The new coil will sit inside distributor cap (4 screws). The distributor wires plug into the coil leads (12 Volt/ Tach) on top of the distributor cap.
You'll need a coil cover to make it work if it doesn't come with one. (2 screws) Simple install...
zedtwentyate
I got the unit from AAA and it has the cover.
So to be clear...
Purple coming off the starter solenoid is useless...tape it up or remove it.
Yellow coming off alternator is useless...tape it up.
Grey off the harness is tach
Purple off harness is 12v
Is that right? Or should I be snagging my 12v elsewhere?
Kegan
Sounds right. As long as you have 12 volts, key on, you should be fine.
zedtwentyate wrote:I got the unit from AAA and it has the cover.
So to be clear...
The yellow wire maybe a exciter wire for the alternator so you may need to hook that to the 12 v (purple wire) I don't have a diagram in front of me did that wire go to the + on the coil ?
Let me back up here , Do you happen to have a ballast resistor on your engine ? If you do that will need to be by passed
The wire coming from the solenoid was for the ignition coil which provided the needed 12 volts while cranking. You won't need it...
zedtwentyate
Long grey wire on the left is my tach wire. The two together on the right were connected to the + terminal. The yellow cam from distributor and the purple goes into the harness. There was another purple wire from the starter to the positive terminal on the coil too.
Kegan
zedtwentyate
Kegan
mrrudely
Post by mrrudely »
hey guys I realize this is an old thread but I am about to swap out
my distributors with HEI's from AAA marine
Looks like zedtwentyate has already done this
if you're still out there the wiring has me a little confused
especially the part about the alternator
so you asked the question
grey off the harness is tach
purple off the harness is 12v
but I didn't see the answer
thx
rr
any other tips much appreciated
10 meter mid cabin
