I have a closed cooling system with center rise manifolds and 3" riser extension blocks. What is the preferred gasket at the manifold to extension block connection point? I would have thought block off gasket then block off plate and block off gasket. When disassembled it was open gasket then block off plate and open gasket. It doesn't really matter as long as the plate is there right???
Thanks!
Closed cooled gasket question.
- Diverted Income
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: Closed cooled gasket question.
With the plate there it really make little difference .
X2prowlersfish wrote:With the plate there it really make little difference .
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
