The Phoenix II
The Phoenix II
What a great day we pressurized with city water pressure and all systems worked. Had to install a new pressure switch and filled the tank, success though pressure is not what I want will work on that, at least all water accessories are working. :D
Re: The Phoenix II
Good Deal
aaronbocknek
Re: The Phoenix II
Post by aaronbocknek »
it's always good when life returns to the boat. next up for me is a replacement shore water hookup. at least for now, things are status quo.
aaronbocknek@gmail.com
Re: The Phoenix II
boat originally had a y valve for black water but apparently it has been removed and uses two macerator transfer pumps, which bot are running to move effluent to central storage holding tank. The boat has a water heater but says 2.5 gal I think it may be on demand. In any case made hot water. Will have to check on its specifications, if not sufficient will replace with largest available an have engine heat option, although on a 90 mile long lake can always return to covered dock and have a shower there. While removing one of the carbies I failed to disconnect the bimetallic spring for the choke and apparently damaged it. Now the choke stays clamped closed, so need a new one and while at it will replace both. I have Crusaders 270s does anyone know where to get the bi-metallic choke assemblies? I found them but $49 each I thought was spendy for a simple piece.
Larry
