Sherwood g5 to g7 raw water pump rebuild
Need some experienced opinions---- when reassembling would you use just the o ring,o ring and sealant,o ring and gasket or just the gasket------- my pumps do not have the end plate as they came apart---- too many choices in the kit,I know this kit fits other pumps and these do have the o ring groove---- maybe some overthinking but----Mike
Re: Sherwood g5 to g7 raw water pump rebuild
a picture would be helpful, but if there is a groove for the o-ring I would just use the o-ring by itself. I used just the O-rings on my G5s. O-rings are pretty good methods of sealing. My backhoe used fittings with groove on one side and flat on the other, and holds thousands of pounds of pressure with a single o-ring there.
In reality how much water could really leak from behind the cover plate if nothing were there. :)
Thanks for the response Larry----I believe my pumps are the G5---I put them together with just the O ring, just that I saw some other alternatives and was wondering if anybody had found a better way of doing it ---Mike
Just using the O-Ring is the right way .
prowlersfish wrote:Just using the O-Ring is the right way .
thanks----- you never know what someone has done before you with these old boats---- I like to put things back the correct way for the most part---- Mike
