Trim tab hose
Diverted Income
Trim tab hose
Post by Diverted Income »
What size is the hydraulic hose on trim tabs?
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: Trim tab hose
I use 1/4" I.D. pressure line hose. No problems so far...
Re: Trim tab hose
I have used automatic trans cooler line for this .
Re: Trim tab hose
The Dog House
Re: Trim tab hose
Post by The Dog House »
The Boat Leveler trim tab hydraulic hose is 1/4 inch ID and 1/2 inch OD. The working pressure is 400 psi and the burst pressure is 2000 psi. Bob from Beacon mentioned that he had some. You can also get it from Boat Leveler (Insta Trim).
