Hey yall, new member, I have a F26 Express.
I found that my prop is brittle from electrolisis and am looking to replace it. this is what i know (from what the diver said);
15" prop
Has 3 blades
1" Shaft
Right Hand
but I dont know the pitch....
I did some looking and found a boat owner's page saying he had a prop he thought was origional and said it was a 13RH10.
The engine I have is a 1977 Chrysler 318
Would anybody know what prop i am looking for or the best performing prop that would fit best?
Thanks for your help.
RJ
What Prop do I need??
- Moderator
- 2026 Support
Re: What Prop do I need??
RJ , I moved yopur post to the boat section "Trojan Boats Forum", the pont. section is for none boating stuff . I am sure you will get some help here .
Welcome to the forum
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Forum Moderator
TrojanBoats.Net
Trojan Boater
14x10 small cup is what I have listed . But remeber the stock prop is just a staring point. depending on what gear you carry and how you use the boat some ajustments may be needed .
- The Dog House
I have a 15 x 11 prop with no cupping on my 1971 F26 Express. My boat has a V drive. I believe the straight drive F26 boats used a 14 x 10 with cupping. A 1977 F26 should have the straight drive.
