2 part question, batteries and starters
jaahmez@hotmail.com
Post by jaahmez@hotmail.com »
Launched the boat today after 2 years of lay up and updating. Tractor trailer to travel lift to water. It's awesome, ran great. My starters are crappy, and I want to replace them. I'll rebuild the old ones some other time. Any reccomendations here in the Washington DC or Annapolis/Baltimore area for retail Arco or other replacements? I know of Cobe Marine in Pasadena. Any others?
As far as the three batteries go, with 350's (7.4) and a 6.5 Onan Gen, Can you chime in on what your setup is (group/specs etc). I'd love to hear.
Its a 1984 11M Express, mains and gen original.
James
Vitaliy
Post by Vitaliy »
sorry cant help u with the store locations as i buy lots of this type of stuff online however i can tell you what i run in my boat
i had all of my batteries boil over on me (charger went on the fritz a few months ago) so i decided to replace them with diehard marine batteries... havent had a single issue thus far... 750 CCA
1974 F36 Tri-Cabin "Jorallyn"
I have had very good luck with ARCO .
Bob at beacon ( the site sponsor ) has new ARCO for sale in the for sale section . The Ad says F boat but should be the same ( Bob can tel you )
http://www.trojanboatsforum.net/wforum/viewtopic.php?t=6538
I don't go with anything less than 1000 MCA/800 CCA anymore. 550-650 CCA for the genny should suffice. Both 24 series is fine.
7421f
Post by 7421f »
Hi James. I too own a 1984 Trojan 11m (370) Express with the big blue gassers. My battery setup is 3 Trojan group 27's, one for each engine and one for the generator. They are 27SM-1100 with 860 CCA @ 0 degrees. I am happy with them, but Trojans are not in the least tolerant of a low water situation in the cells. I check them weekly. I use an 8D battery for my house battery. As far as brand of batteries, there are not that many manufacturers. When I need to replace, I will buy Kirkland brand from Costco. Good price, great warranty, made by Johnson Controls. The ones I have came with my boat. I'm looking at a starter replacement too. So far Arco looks real good. Here's a link to a good distributor: http://www.ase-supply.com/default.asp
Best of luck to ya!
1984 Trojan 11 Meter Express "My Vixen"
Big Blue 454's
http://photobucket.com/MyVixen
If the budget allows, the 4 cycle charge algorithm of a good quality Smart Charger minimizes the loss of electrolyte. Since installed, I still check but never worry about it any more; my batteries lose very little.
jefflaw35
Post by jefflaw35 »
another good bookmark, im doing a 4 battery bank and 2 bank, this will be good info to look back on....
jaahmez@hotmail.com
Thanks for all the help
Which motor matches which starter?
Is the Port (LH350) the CW or the CCW starter?
Pretty sure it would be CCw, no?
jaahmez@hotmail.com wrote:Thanks for all the help
be careful here
do not swap starters or have the rebuilder make a "mistake"
cranking an engine backwards from it's inteneded rotation could cause water ingestion.
Visual always helps. Copy the pic and save for future refference:
[img][img]http://i945.photobucket.com/albums/ad29 ... tation.jpg[/img][/img]
Courtesy of Google
7421f wrote:....As far as brand of batteries, there are not that many manufacturers....
Agreed, however, not all batteries are created equal. Don't be fooled into buying a lower cost brand because it's made by a company you know manufactures high quality units. That manufacturer will have a complete line that differs in quality/construction to accomodate a given brand's requirements; be it quality or affordability/price point; ie. you wouldn't find a $50 24 series battery from a big box store in my boat even if I knew it was manufactured by the same company that makes a $200 model of the same size.
GREAT CHART BIG D .
A few notes
You can't always go by what side the engines are on . I was working on 2 Trojan meter boats last year , one boat had a CCW on the port (left) the other had the CW on the port (left )side .
The norm nowadays has become 2 normal rotating engines and using the transmissions to change direction ( been that way for years on diesels ) so if the boat has been re powered take note . you won't fine a counter rotating 5.3 or 6.0 .
HEADACHE!!!!!! :lol:
I know which mine and only mine turn. :D
larryeddington wrote:HEADACHE!!!!!! :lol:
You got that right it can be a big headache . both mine turn the same so its easy.
prowlersfish wrote:...You can't always go by what side the engines are on...The norm nowadays has become 2 normal rotating engines and using the transmissions to change direction....
Agreed Paul; MUST know what you have before buying hardware.
Larry loves this subject :wink:
