Control Box
- The Dog House
Control Box
Has anyone ever converted the two lever control box (transmission and throttle) to a one lever control box? My last boat had a one lever control box, and it seemed much easier to use. Are there any advantages to the two lever control box in a single engine boat?
called morse and discussed it with them. They recommend mt3 model and they make a device that allows you to do just that. I decided to leave mine as original. But it can be done, don't know if the control friction would increase. Original you are working both sets together so I did not think it would be much different.
You are right single controls are easier to use.
jefflaw35
Jeff,
Yours is a single engine and only one control station I think, It is easy in that case, but gets more complicated with dual station as does haveing two engines. You have to have a device that sort of couples it all together.
jefflaw35
jefflaw35
- ready123
Is it really better to have a single lever for handling a single inboard boat?
I am used to it on single I/O's but would think with a single inboard using the shifter with revs set would be more accurate in tougher docking situations?
I may be out to lunch since never having a single inboard.... what do other's think?
- The Dog House
For a twin screw boat, splitting the throttles and transmissions makes sense because during low speed maneauvering the boat is being steered with the transmissions. The helm and throttles are rarely touched. The helmsman has one hand on the port transmission and the other hand on the starboard transmission.
For a single screw boat, the helm has to be used. With my current setup, the primary controls are the transmission and the helm. Since the rudder has less authority than differential thrust, it is necessary sometimes to also use the throttle. At those times, I need three hands. Having a combined throttle/transmission would allow me to eliminate moving my hand from one control to another.
jefflaw35
jefflaw35
