Shore Power circuit
Shore Power circuit
Im having trouble with my shore power...i checked for juice coming from the dock and thats good...after that I have nothing...the push button reset switch isnt even lit up...i am thinking that its the main breaker switch...any ideas??
kjs
- jblack1036
It's happened to me.............I spent 30 minutes one day after hooking up the shorepower trying to figure out why I wasn't getting any power to the panel and looking for the reverse polarity light to show green or red. Then it dawned on me. I needed to flip the main breaker on my main panel. Then all was good. I got the green light and then flipped the rest of the breakers I needed. Felt like an idiot at that point.....I call them "BRAIN FARTS".......
Jim Black
31' 1965 Trojan Sea Breeze (Wiskey Girl)
29' 1974 Caver Monterey (Rough -N- Ready)
Re: Shore Power circuit
You mean you checked at the dock pedestall? Did you check at the end of the shore power cord that hooks up to the boat to see if there is power there?....could be a faulty cord. Where is the last place you measure 120 volts?kjs f-25 wrote:...i checked for juice coming from the dock and thats good...
X2Big D wrote:You mean you checked at the dock pedestall? Did you check at the end of the shore power cord that hooks up to the boat to see if there is power there?....could be a faulty cord. Where is the last place you measure 120 volts?kjs f-25 wrote:...i checked for juice coming from the dock and thats good...
