Cruisair reverse cycle A/C
7421f
Post by 7421f »
Does anyone have an owners manual for an older (1984) Cruisair A/C?
Mine worked fine on dock power before I had the boat transported by truck to my home port. Now it trips the reset in about 1 minute. Could the water pump system have gotten n air-lock? Thoughts/suggestions welcome as I could find very limited information online.
1984 Trojan 11 Meter Express "My Vixen"
Big Blue 454's
http://photobucket.com/MyVixen
First welcome to the site .
Sounds like the water pump may not be pumping . turn on the a/c and see if its pumping water be for it pops the breaker . yes it could be a air lock . Is the thru hull valve open ?
prowlersfish wrote:First welcome to the site .
I Agree. The same thing happens to mine every time its removed from the water. To solve the problem, I hold a garden hose against the bulkhead fitting that the A/C water drains from and turn it on. This back washes water thru the system and purges out the air lock.
Also as Paul stated, be sure the valves are open. :D
jhalb
Post by jhalb »
I found my early 80's intallation/operation/maintenancs manual for Cruisair air. do you still need it?
John
"PELICAN"
1983 10 Meter Express
7421f
manual for Cruiseair
Post by 7421f »
Hey John, a manual would be great...Don't suppose you've digitized it??
Thanks to all that replied. I did get it back in operation this afternoon and it was indeed an airlock in the sea water system. I could not get a water hose to it, but cycled the unit on/off a few times for about 30 seconds each and it cleared on it's own. Once again, I have my "cool" restored! On to the next puzzle to solve- air leak in my "Star Trek" doors' compressor system 8)
Big Blue 454's
k9th
Post by k9th »
Welcome aboard Tim from another Tim.
jhalb
Re: manual for Cruiseair
Post by jhalb »
7421f wrote:Hey John, a manual would be great...Don't suppose you've digitized it??
I can scan it this week. PM me your email address and I will send it when i get it done.
John
"PELICAN"
jaahmez@hotmail.com
Post by jaahmez@hotmail.com »
John, sent you a request for the manual as well. I would be a happy guy as the A/C is the last item on the list of my 2 year redo and I currently can't even find power at the switch from the panel.
Tim, star trek doors are all surgical tubing running off a compressor and 3' accumulator tank under the hatches in the main cabin that are in front of the head door (opposite the forward bilge pump on the port stringer).
I took it all out and tossed it, about 70-80 pounds worth. I removed the plated pushbutton switches and installed Decora block plates over them at 1.70 ea from the Depot. I cut off the screw tabs on the decora so I had a nice rectangular plastic plate.
They look good, the doors slide nice manually.
My old Cruisair unit's compressor finally went south a few years ago so I replaced it with a newer model along with the SMX digital control.
Below is a manual which is for both the rotory knob and SMX units. Including wiring schematic for the 3 knob system.
http://www.dometic.com/FileOrganizer/1- ... ration.pdf
jhalb
Post by jhalb »
This looks complete. Does anyone still need my 80's copy scanned?
John
"PELICAN"
7421f
Post by 7421f »
Hey John,
I think I do need the information you have. My AC/Heat unit has a Digisette Aqua-Temp control that is not shown on the posted manual. Does your information cover this control? I noticed that my compressor comes on when I switch the unit to "fan" It should not do that. I need to find and repair the problem.
Big Blue 454's
Landlocked
Post by Landlocked »
To 7421f - When my 1985 11 Meter Sedan kicks on the compressor even though the switch is set to fan I have to replace a solid state relay in the compressor's control box. I don't have the specs here with me, but it is a 240 volt relay about 1 1/2" x 1 1/2" x 1/2" in size.
This seems to get damaged if we switch to genset or shorepower without first turning the A/C off. I bought a couple of them recently because I thought I had blown one, but I was wrong. I still have both of them. If you have trouble finding one i could figure out a price for you on one of mine.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
Burnninator
Re: Cruisair reverse cycle A/C
Post by Burnninator »
If anyone has the early 80's cruisair manual digitized I would really appreciate it.
1984 Bertram Flybridge Cruiser.
Thank You Corbitt Lewis
