helm switchs--wiring?
brucehouse
Post by brucehouse »
Hey everyone---Its the guy with to many questions and heres another for all.
As some know the push button momentary start buttons have 4 spades on the back. Grouped wires of purple, purple with stripe, yellow and yellow with strip. Question is: if a guy was to install a new push button what is the least amount of "spades' he could do it with? And how would he group the wires? anyone have a clue? maybe split them to an on/off and a momentary?
a note: there is a guy with the original push button switches for sale on ebay. put in Marquardt and you'll find him. selling them for 17.00 each BUT OF COURSE THEY ARE THE ON/OFF NOT THE MOMENTARY.
thanks for the help in advance
The Rules
1. if your not happy---get out
2. Show respect until none given
3. Dont mess with another mans woman
4. Dont lie, cheat or steal
5. Above all take care of the family
6. You can break 1-4 to take care of no. 5
Push button switches ? the thought they used a off-on-momentary toggle switch ? No mater what type the stater needs to be a MOMENTARY switch
brucehouse
yes, the starter button must be momentary. the problem is: original switch has four spades and (if i remember correctly) 8 total wires coming in and out. I cant find a 4 spaded toggle, pushbutton or rocker switch that has 4 spades for all the wires to hook to.
so I am trying to find out can and how would you group the wires to use a 2 spade pushbutton or toggle.
The Rules
mitch
Post by mitch »
$4.00
These LMA weatherproof starter buttons are ideal for when electrics may become exposed to moisture, dirt or other contaminants.
http://www.demon-tweeks.co.uk/Product.d ... n=Switches
mitch wrote:$4.00
Mitch . thats 4 euros as those switch's are in the UK
have you tried beacon ? can you post a pic ?
fourreins
Post by fourreins »
I have bought the original switches from Beacon so I know Bob can get them.
Commissionpoint
Post by Commissionpoint »
prowlersfish wrote:
mitch wrote:$4.00
Paul those are priced in dollars, and England uses the Pound Sterling not the Euro.
hmc
Post by hmc »
4.08 EX ? ex ? exchange rate ???
f boat ( glass )
TROJANS !!!
Commissionpoint wrote:
prowlersfish wrote:
mitch wrote:$4.00
your likely correct I just saw ex and thought eu . bet the shiping is cheap.
Normally when someone overseas selling somthing in our money you see 4.00 USD .
brucehouse
push button start button
Hello, I first want to thank everyone for the help. I started at the helm with a meter----everything was hot. traced the cables down to the engine room. once there I changed the solenoid just because I had one and tested it-----nothing hot. started tracing the wires back.
the solution to my start buttong not working is it thought the trany was in gear. the wires go---helm to trany to start breaker to solenoid to starter AND the wire to the trany had a break in it about 3 inches up from the connection. repaired and helm start button worked. SO be sure if you have a starting problem, be sure to check the wires at the transmission. if they're not good the entire thing shuts down..
again thanks for the information and I will post pics of my boat hits the water tuesday. to much wind to launch the last 5 days so tomorrow is it.
Bruce
The Rules
