What size packing?
Bubbabuda
What size packing?
Post by Bubbabuda »
Can anyone tell me what size diameter packing material to use for my prop shaft seals and rudder shafts? Application is on 1975 F-32. I measured the prop shafts, 1.25 inches.
1/4 on the prop shafts , what is the shaft size in the rudders ? If its also 1-1/4 also it would be 1/4 also
1/4" and 1/4" for both I believe.
rbcool
Post by rbcool »
Quite often I used 5/16.... mashed it a little flat with a hammer. Gave me more material in the housing.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
rbcool
Post by rbcool »
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Bubbabuda
Post by Bubbabuda »
The rudder shaft looks to be smaller, I will measure today. I checked and found 'Graphtex Ultra Flex Shaft Packing'. Is there any other better products? And when I make the cut, do I make the cut at a 90 or a 45?
Thanks for all the help. Rick
rbcool
Post by rbcool »
Your supposed to "Miter" the cuts at 45 , then stagger the joints
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
rbcool wrote:Your supposed to "Miter" the cuts at 45 , then stagger the joints
Ron 8)
Exactly ! I Bet Ron's shafts don't leak
This may help
http://www.diybob.com/diyPackingGland.htm
'Graphtex Ultra Flex Shaft Packing' or Gore tex is the best you can use IMO
rbcool
Post by rbcool »
They don't leak..... they're "Dripless"!!
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Thats cheating . :D
rbcool wrote:They don't leak..... they're "Dripless"!!
Ron 8)
that's a oxymoron when they leak.... :lol: :lol: :lol: :lol:
but I seen the PDF for packing and it said graphite packing, now I was taught in the Navy that was a no no due to it will can in to the shaft if it gets to hot. And it will I've seen it, I use old school gar-lock packing and pack it water proof yellow valve grease it works for me, and I try to keep in the tech level the boat was engineered at for the time
rbcool
Post by rbcool »
The only nightmare with mine is if the water lines going to them get clogged...... then I'm screwed!! :roll:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
rbcool wrote:The only nightmare with mine is if the water lines going to them get clogged...... then I'm screwed!! :roll:
Ron 8)
I haven't really been following everything, but am I understanding you are using dripless seals? If so, what brand, and how well are they working for you? How did you plumb the water feeds? If you think we should deal with via PM or in another thread, I will ask you to kick it off.
Bubbabuda
Post by Bubbabuda »
Thanks Ron for you'r post about dripless seals. Where my boat is located now, the Mohawk River in NY is very muddy. Going to stick with flex packing for now. Thanks for all of the information. Next week the weather is supposed to be in the 70's all week. Hope to get alot of work done.
