It looks like I’m going to need to change out my prop shafts on my 10m Express project. The shafts are pitted and have some worm holes. I was planning on installing some new cutless bearings anyways but now I’m looking at new shafts, stuffing boxes, etc as well.
Does anyone know the length of these shafts? I know they are 1.25†with a single taper. What I don’t know is the length which I need to order the new ones. I’m not sure if I will be able to get the old ones out without cutting them up (see below).
So far I have been able to get the prop off. I made a cutless bearing removal tool (pic below) so I could remove the bearings with the shaft still in place. However, I tried removing the bearings this weekend and they definitely don’t want to come out. Yes I removed the set screws. Any ideas? If I can’t get the bearings out I will either have to cut the shaft or take the struts off.
I also made a shaft coupler puller (pic below). I tried using that also and I need to get some longer bolts. From what I can tell so far, that thing definitely does not want to come off and there is a chance I will have to cut the shaft there as well. The coupler diameter is too large to come out with the stuffing box all in one shot.
So, here are my questions:
What is the length of the shaft and if I order a single taper at the appropriate length is that all the information I need?
Any ideas on how to get the bearings out? I’m reluctant to add heat because of the plastic/polymer aspect of the bearing.
Should I avoid removing the struts or is it pretty straight forward to do? I checked and I do have access to the backing plates. Since the motor is still in, I can use that for re-aligning the struts?
If the shaft coupler is pressed on so tight, so in the heck am I going to install it when putting the new shafts in?
Any additional words of wisdom?
