Does anyne know how long a port side shifter cable (or all four) are for a mid cabin?
I tried lubing it using a compressor/marvel mystery oil but the jacket has physical damage so I need to replace it.
It would be really hard to measure w/o removing it first and I'm trying to avoid the downtime.
thanks,
mid cabin shifter cables
Ditto Paul. They usually have a model number on them. The number usually includes the length in inches (last part of number). The number is usually closest to a cable end; at the shifter or tranny, carb etc. Good luck.
Usually within a couple of feet of the ends but you never know with older vintages. May have also worn off. Hopefully someone with the same model that knows the length for sure will come along soon and pitch in.
