Autopilot
stevedorej
Autopilot
Post by stevedorej »
Hi, I'm new here so I'm still getting my feet wet.
Anyway I am looking for an autopilot for a 1987 Trojan 10meter with hydraulic steering where I can also tie a Raymarine C-Series. I'm having a hard time finding compatible autopilots for this. Can anybody please help. thanks
I always see some on ebay.
k9th
Post by k9th »
Welcome to the forum.
g36
Post by g36 »
when i was looking a while back the kits i was looking at basically you t'eed into the hydraulic system at the helm pump.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
stevedorej
thanks everyone. I'll check all your suggestions out.
i HAVE THE rAY MARINE c SERIES WITH THE AUTOPILOT
tHE MOTOR AND HYDRAULICS ATE SET UP AT THE (SORRY ABOUT THE CAPS LOCK)
The autopilot system is set up at the rear, simply remove the two starboard side access panels - the small one and the locker and it's a reasonably easy job.
I used STARBOARD to make a bracket to hold the sensor.
Otherwise if I had to do it all again, I would NOT use the Raymarine system.
I have replaced 2 flux capacators (one under warranty) and the radome unit (also under warranty) and I find the plastic connectors at the back of the chartplotter to be less than sturdy.
NEVER AGAIN
