Where to get parts for Onan generator
Where can I get parts for my Onan generator. I specifically need headgaskets for it. It is the generator for of my 1981 F36 Tri Cabin,
- ready123
Re: Where to get parts for Onan generator
Where are you located?TurboTim wrote:Where can I get parts for my Onan generator. I specifically need headgaskets for it. It is the generator for of my 1981 F36 Tri Cabin,
Why not put it in your profile.....
Onan is owned by Cummins now...
http://www.cumminsonan.com/
There should be a number somewhere on it , unless your the original owner you don"t know if its the same gen-set that came in the boat , so getting a number from someone else could lead you to the wrong info.
Don't know about '80s vintage but the older onan engines had a serial number stamped on the block on a protrusion just in front of the lifting eye. Can you post a pic of your unit? It would help.
