Stripped Threads
k9th
Stripped Threads
Post by k9th »
I was tightening the screws that hold my salon windows in place today and noticed a few were stripped - not the screws but the threads in fiberglass and wood frame behind the window. What is the best way to fix these?
jddens
Post by jddens »
I just repaired some stripped holes holding my railing mounts. I filled the holes with west system epoxy, let it harden then drilled new holes slightly smaller than screw, filled the hole with 3M 5200 put the screws in...worked great............John
1998 Kawasaki ZXi 1100
I agree with John except for the 5200. It's a good choice only if you don't plan on never taking it apart again. If you want the the screws to remain serviceable, try 4200 or Lifeseal.
Apply heat to the fastener with a gun, that'll allow you to remove again.
