has anyone tryed poly glo
mr elevman
- alexander38
Seen a few boats after it was on for awhile. They looked yellow
poly glow
I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
I also read that mop-n-glow is the same stuff which makes sense.
davidsmith
poly glo
My F-36 was very chalky. We tried compound and wax, lasted about three months chalk was back. Put 5 coats of Poly Glow on last spring and it still looks like it did the day we put it on. It dosent have the shine that wax does but the chalk has not come back and it is easy to apply. Also very easy to keep the hull clean, nothing seems to stick to it. Going to put one coat on this year.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
i use it and have been for the last 3 years. my boat isnt yelllow and there is no peeling at all. i will continue to use it. if you dont put it on according to the instructions then there might be some problem with adhesion but as of yet i have none. i have many complemnets .
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
Re: poly glow
====================================BobCT wrote:I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
been there, done that on a 22' Grady White.
Looks GREAT for a while.
I was truly impressed.
Once it starts to go, it goes BAD.
Run Away !
Unless you are looking for a quick sale.
Re: has anyone tryed poly glo
No.mr elevman wrote:has anyone tryed poly glo
But I think Paul is experienced with Poly GRIP ....
- alexander38
Hey hey! I didn't say a thing about poly-grip , I could've taken shots on this one, the king is gettin cut on because he popped at the all you can buffet
is that what you excepted ?
foofer b
Gotta chime in. My super structure was very badly oxidized. I compounded, buffed, waxed and swore and it was still chalky. I put poly glo on my boat three years ago and it still looks great with no recoating. I do store my boat under cover, but most of ya'll do too, at least six months of the year. Dirt does just rinse off
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
I was able to spend some time last Fall with a fiberglass restoration pro who does this stuff for a living. He both told me what to do then gave me a demo on a badly oxidized 40 year old FG hull. First he sanded the entire hull with 220 grit in a high-speed orbital sander (the sandpaper does NOT harm the gelcoat). Next apply a liberal amount of 3M heavy duty fiberglass rubbing compound using the same high-speed orbital sander but this time with a heavy buffing pad. Finally finish with a high-quality marine paste wax using a standard power buffer. When done my girlfriend could have applied her makeup in the reflection of the hull.
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
