Needed F32 Heads
fastestonehere
Needed F32 Heads
Post by fastestonehere »
I need a set of heads for a 1984 F32 Chrysler 360's "crusaider"
old set to far gone. any help...
sorry if this is not in the right section.
"She's Wide in the rear"
Re: Needed F32 Heads
fastestonehere wrote:I need a set of heads for a 1984 F32 Chrysler 360's "crusaider"
If its a Chrysler its not a Crusader . You could get a set of 360 dodge truck heads from a bone yard and use them . ( install brass freeze plugs) .
Check with bob or maybe try here
http://bpi.ebasicpower.com/pc/CYLCHR-183/ALL2A
http://www.dougrussell.com/Products/ind ... &Brand=102
Any small block Chrysler head will fit.
273, 318, 340, 360.
As Paul says, Be sure to use brass expansion plugs.
fastestonehere
thanks i will check it out.
