Engine/trans manuals , wiring colors and Packing sizes
Locked
_________________________________________________________________________________________________________
ENGINE MANUALS __________________________________________________________________________________________
http://www.correctcraftfan.com/reference/manuals.asp
  • > Chrysler LM318, M440 Marine Engines
    > Ford Interceptor Marine Engines
    > Ford 302 & 351
    > Crusader 198
    > PCM
    > Velvet Drive Installation and Service Manuals
    > Morse Controls
    > Teleflex Steering
VELVET DRIVE SPECS, RATING & MANUALS ________________________________________________________________________
Velvet Drive 71c-72c Series (Straight Drive):
http://RNR-MARINE.com/TROJAN/Borg-Warne ... _Specs.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... atings.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... Manual.pdf
Velvet Drive 5000 Series (Down Angle Drive):
http://RNR-MARINE.com/TROJAN/Velvet-Dri ... ochure.pdf
http://RNR-MARINE.com/TROJAN/Velvet-Dri ... Manual.pdf
WIRING COLORS ___________________________________________________________________________________________
ABYC Standards:
Marine Wiring Color Code - Direct Current Systems Under 50 Volts
http://www.glen-l.com/weblettr/weblette ... iring.html
http://www.ftkltd.com/Boat%20Wiring%20a ... 0Codes.htm
OUTBOARD MOTORS:
Re: Packing
Packing info
1" uses 1/4" packing
1 1/8" shaft uses 3/16" packing
1 1/4" shaft uses 1/4" packing
1 3/8" shaft uses 5/16" * packing NOTE See updated info below 7/9/18
1 1/2" shaft uses 1/4" packing
1 3/4" shaft uses 1/2" packing
2" shaft uses 3/8" packing
2 1/4" shaft uses 7/16" packing
2 1/2" shaft uses 5/16" packing
3" shaft uses 9/16" packing
* On the F36 conv. Trojan calls for 1/4 packing . Buck Algonquin calls for 5/16 . It is my belief both sizes will work without issue . Thank you
Locked
